CMOS sensor
Hello guys,
       Is there any third party or reputed CMOS camera industry/company that can be programmed and controlled using labview ? ( As in they DO provide LV drivers ).
Anyone got any experience working with low cost CMOS camera/Image sensor or can suggest any known companies ??
Thank you.
Abhi
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(4,672 Views)
I've used CMOS cameras from Balser, it's not low cost though.
As for the drivers, well I guess the easiest is to get the Vision Acquisition Software driver from NI, it support all NI framegrabbers as well as GigE, USB and FireWire cameras.
But by the way, why only CMOS? Need speed?
Hope this helps a bit
Epictetus
Antoine Chalons
(4,655 Views)
yeah . Need speed and my research project is confocal microscopy that needs a point to point scan that can be very fast , so each point I want an image.
BASLER right ?? Let me have a look. I was also looking at http://www.theimagingsource.com/en_US/ , their cameras claims to come along with LV drivers.
I havent seen much posts on NI forum based on this company though.
Anyway , will post my views once I get through with BASLER.
Thank you.
Abhi
Abhilash S Nair
LabView Gear:
(4,638 Views)
Never used Imaging Source... The VIs given by basler to change camera settings works but is far from complete, if you go for Balser and need help I can give you my enriched version. Send me a private message if you need it.
Epictetus
Antoine Chalons
(4,634 Views)
Thank you.
Abhilash S Nair
LabView Gear:
(4,630 Views)
