11-05-2017 01:46 AM
I am sitting the LabVIEW CLD-R exam in a few days & attempting some of the sample questions.
Question 22 has me stumped, I just don't get it.
I tried it in LV 2015, and can't seem to get the correct answer.
Can anyone explain to me whats happening here, (I generally don't use recursion, which is why I don't get it I suppose).
I will attach my attempt (that does not work..)
Thanks in advance for anyone's help
Solved! Go to Solution.
11-05-2017 03:27 AM
Just to help... attached is the actual question, just in case people don't have the exam papers.
And apparently, this is is the correct answer, (the VI attached)
Kevin
11-05-2017 05:08 AM
Your VI-upload contains one error in comparison to the sample exam. You missed to connect the string "ExprOut". Add this to your VI:
There's also a second smaller problem with the suggested solutions from that sample exam: it is written for an environment with a dot as the decimal point. So it you use a comma as the decimal point, that's why I added explicitly the false constant to the conversion to string.
Regards, Jens
11-05-2017 02:44 PM
Very good... thank you very much.
I cannot believe I missed that... no excuse I know, but it was late at night I was trying these (so obvious now that I see it...).
Now that I see it working I get it, thanks heaps.
Kevin
11-19-2018 06:52 AM
Hi you guys.
Still I can´t get why answer D is the right one. Probably something related to recursive function? I was learning about this but still can´t get the reason why D is right.
Can anyone help me?
11-19-2018 07:45 AM
11-19-2018 07:57 AM
Thanks Jeff, but, opción B also stops recursing the VI. so whats is different there?
11-19-2018 09:08 AM
The only real difference I am seeing is the Result double being stored in a shift register. I would need to spend a lot more time going through the code to figure out if it really should be there or not (my current thought is NO).
11-19-2018 09:30 AM
You are thinking correct. The result of the incurred step is the output of the case. so the loop output is not what you want as the result.
11-19-2018 02:02 PM
Thanks !!!
