CLACULATOR BOTTON INTERFACE
I want to use a front panel with number bottons looking like the windows calculator.
I have made this front panel with the bottons, but it doesn't work right.Instead of the numbers to add from left to right,every new number that I press erases the last one so I am left only with a single digit number.
I am sure this is a common feature in many VI's.
Does anybody have an example how to do this ?
(5,689 Views)
Hi tzviel,
If you're using a numeric indicator rather than a string, the trick is to shift the value displayed (x10) and add the value of the button pressed.
I hope the attached VI is useful.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(5,676 Views)
I would recommend starting with the Formula Express VI. There are also other examples that use a calculator interface.
Hope that this helps,
Bob
(5,667 Views)
Thank you for replaying.
SandmanUK, do you have this example in LV 7.0?
Tzviel
(5,642 Views)
Hi tzviel,
Here you go:
(5,636 Views)
It works pefectly !
I just need to use a decimal point also -I think I can make it by myself.
Tzviel
(5,627 Views)
