CIN stack overflow error
Im using an recursiv c++ function in my VI.
After severall calls the VI crashes, printing an
stack overflow error.
I already increased in Visual Studio 6.0 the Link
setting: allocate stack. But nothing changed.
I need help fix this problem!!
My prg. looks like this:
recursiv (....) {
int array[..][..][..];
recursiv (..);
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,695 Views)
> recursiv (....) {
> recursiv (..);
If you are truly allocating a three D array of ints
on the stack, then it makes sense that you will run
out of stack space sooner or later. I can't help
you with increasing the stack size, but if you move
your array into a memory block and store the pointer
on the stack, then you will use less stack space and
avoid the problem.
In otherwords:
recursive() {
int *array;
array= DSNewPtr()
array[][][]= ...
recursive();
DSDisposePtr();
Greg McKaskle
(4,695 Views)
