CIFIX 50E-DP slave Driver Handling Problem.
I also have problem, with handle, the CIFX 50E driver handling in Labview, because for windows 10 driver has changed
significant. I dont know, hogy should i handle pointers, C typedefed structures, values of structures. I dont know, how
sould i read the values of conllex variable (wich defined in dll) if i only have returned pointer in Labview.
I found worhking examples for the old Cif32dll.dll, but for windows 10 the had write the new cifX32DLL.dll (significant
changes).
Should you give me any help, or any example/solution?
I sent informations, driver documentations, and other materials.
Message 1 of 1
(2,741 Views)
