CGI scripts stop running after a while
 I am currently using G server with the CGI scripts in oder to catch the sanpshoots of the panels of some VIs and also can control these VIs just like the CGI example "Oscilloscope" provided in the Internet toolkits. However, After the G server runs for a while, the G server stop calling the CGI scripts. For example, I type the link "http://localhost/psaaword.vi" and the browser keeps on waiting and doesn't get any response. The CGI VIs are not in the running status and the G sever never makes the GCI VIs running again. However, after I push the "run" buttons of those CGI VIs,  the CGI VIs run normally again. But this is not what I want. The G server should start these CGI VIs without pushing the "run" button for thos VIs.
 Does anybody have ideal about this situation? What is the start point to solve this problem? Thank you very much.
Best Regards,
Benjamin Chu
(2,778 Views)
Hi Benjamin,
I would like to take a look at how you call the VI, can you attach a screenshot or the VI in question. Here are some examples that you should find helpful:
http://digital.ni.com/public.nsf/websearch/18CCA6D9573709B386256F0000682B28?OpenDocument
Also, Does this happen with all VIs you are trying to call or only the specific one you mentioned?
Sappster
(2,749 Views)
 Thanks. It is strange that the problem doesn't exist for several days. I will continue to track the web-sever to see if it happened in the future. Thanks for the help.
Best Regards,
Benjamin Chu
(2,723 Views)
