CB-68LPR to NI cDAQ 9172
How would I wire from CB-68LPR to NI cDAQ-9172 ?
Message 1 of 8
(3,224 Views)
NI cDAQ 9172 with NI 9263 and NI 9205 and NI 9401
Message 2 of 8
(3,221 Views)
two CB-68LPR boards used with NI 6034E and NI 6703
Message 3 of 8
(3,211 Views)
Hi lakersrl,
If you don't mind me asking what is the end purpose of your setup?  Since the CB-68LPR is just a I/O connector block it really will depend on what you are trying to hook up to it.
Regional Account Manager
NI
Message 4 of 8
(3,190 Views)
tyhe purpose is to transfer all wiring from the CB 68 LPR to the NI cDAQ 9172
Message 5 of 8
(3,184 Views)
one CB-68LPR is for analog input and the other is for analog ouput
Message 6 of 8
(3,183 Views)
The CB-68LPR cannot be connected to the cDAQ modules.  You will need to connect your signals directly to each module.  You can find the pinouts for the module on the module, in the manual, or by right-clicking the device in MAX and selecting "Pinouts".
Otherwise, you will need to pay a third-party company to create a custom cable for you that will go between the terminal block and the modules.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 7 of 8
(3,177 Views)
i understand that, but im switching from CB-68LPR to NIcDAQ 9172 with modules 9205 and 9401 and 9263. New at this, so wanted some help on transferring wiring entering each CB-68LPR pinout to pinouts of modules 9205 and 9401 and 9263.
Message 8 of 8
(3,175 Views)
