CANopen TPDO AND RPDO
Hi
I have problem to understand how to use TPDO and RPDO with LV2017.
Now i have the hardware pci8531.
I have three hardware with CANopen. In the old version threre are Node1 , Node 2 and Node 3 for the name of Hardwares. The old card is PCI Serie 2.
For example :
RPDO1 and TPDO1 from the same Node.
It means RPDO1 fetches the data from device. and TPDO1 transmits the data to software control center, right?
For the three devices i need three nodes. So i can fetch the data from devices, right?
Do i need also SDO and Sync in the program? Thanks!
(4,561 Views)
Hi Zhang,
@Zhangfy wrote:
For example :
TPDO transmits data from your device, RPDO is received by your device.
Which CANopen driver do you use? Mind to share your VI?
SDOs usually are used for configuration of CANopen devices.
In my experience SYNC is needed for TPDO/RPDO…
(4,542 Views)
Industrial communication 2018
(4,537 Views)
Hi Zhang,
haven't used that toolkit so far.
I recommend to read some basic introductions like Wikipedia…
(4,530 Views)
Thanks! I learnt a lot from your suggstion.
(4,486 Views)
