CANopen LLB error
Labview 2014 control and monitoring suite.
cRIO 9068
CANopen module NI9881
I am currently resurrecting a project that was shelved 2 years ago which, amongst other things used a CANopen module in a cRIO to communicate with a motor drive.  This part of the project was all working beautifully.  Now I am trying to get it working again on a new PC and I have issues with the CANopen.  Initially I thought I'd fixed the issue when I copied the CANopen.llb from my old project PC hard disk to my new project PC and the broken arrow went away.  Happy days, or so I thought...
...But when I tried to deploy the software to the cRIO I got an error "CANopen SDO close loaded with errors on target and was closed"
I then recompiled the project and got a broken arrow again.  The errors lead me to "CANopen close polymorphic.vi".  which has the following errors listed:-
Contains unwired or bad terminal
Invalid refnum class
Connected two terminals of different types
I'm completely stumped so any help gratefully received.
Thanks, Ed
(4,108 Views)
Accepted by topic author SubmarineEd
I suggest to install a suitable driver for your product.
Regards, Jens
Kudos are welcome...
(4,100 Views)
I think you should install the NI-IndCom for CANopen into your new PC instead of copying the CANopen.llb from the old PC. Maybe there are some incompatibilities when you use the old CANopen.llb in a new system.
Thanks!
(4,060 Views)
Thanks - This worked!
Regards
Ed
(4,053 Views)
