CAN
I have three loops that operate independently controlling separate devices. I would like to poll them continuously for about five seconds at a time. The reason for polling each of the devices is that I would like to communicate from Labview via one CAN device (8473). Is there an easy way to accomplish this polling/ multiplexing task and maintain each loops independence?
Thank you.
(4,286 Views)
Add a fourth loop that handles the CAN communication.  If I'm understanding correctly that you want to poll each device exclusively for 5 seconds, the CAN loop can poll each device one at a time for 5 seconds, and pass any data received back to the relevant device loop using a queue.
(4,265 Views)
Yes, you understand correctly. I think I undestand what you're suggesting, I'm just not sure how to go about implementing it. It seems to me the fourth loop that you're suggesting that I create would poll each of the other three loops. During each period when a device was being polled the fourth loop would close the correct switches (via GPIB w/ a 34970 which I'm using) to establish CAN communications with that device. The fourth loop would also send & receive CAN transmissions which are the same for each device. My problem is figuring out how I can poll and maintain the independence of the loops. Is there possibly an example in the LV library that might help?
(4,251 Views)
Accepted by topic author chuck72352
Here's a rough sketch of what I'm suggesting.  I don't know if there's a shipping example that demonstrates this exactly, but there are certainly examples on the use of queues for communication between loops.
Message Edited by nathand on 02-15-2010 09:34 AM
(4,223 Views)
Thank you for your help!
(4,215 Views)
