CAN signal Cycle data on and off
I am using C ++ dll wrapping in C #.
The CAN module uses the USB-8502.
I created a session. and I started Session.
If I write Some signal to the some equipment, In some CANDB turns signal to cycle. however, another CANDB sends signal only once.
Why is the behavior different for each CANDB?
※  I created a session using the function as follow.
[DllImport(DLL_NAME, EntryPoint = "nxCreateSession", CallingConvention = CallingConvention.Cdecl)]
public static extern Int32 nxCreateSession(
string DatabaseName,
string ClusterName,
string List,
string Interface,
UInt32 Mode,
out IntPtr SessionRef);
and I started a session using the function as follow.
[DllImport(DLL_NAME, EntryPoint = "nxStart", CallingConvention = CallingConvention.Cdecl)]
public static extern Int32 nxStart(IntPtr SessionRef, UInt32 Scope);
nxStatus_t _NXFUNC nxStart(
nxSessionRef_t SessionRef,
u32 Scope);
and I wrote a signal using the function as follow.
[DllImport(DLL_NAME, EntryPoint = "nxWriteFrame", CallingConvention = CallingConvention.Cdecl)]
public static extern Int32 nxWriteFrame(IntPtr SessionRef, [MarshalAs(UnmanagedType.AsAny)] object Buffer, UInt32 NumberOfBytesForFrames, long Timeout);
//nxStatus_t _NXFUNC nxWriteFrame(
// nxSessionRef_t SessionRef,
// void* Buffer,
// u32 NumberOfBytesForFrames,
// f64 Timeout);
thanks.
(2,180 Views)
Does the issue happen on both CAN ports, or only one?
(2,086 Views)
