CAN read Entries Pending does not reflect the actual value
Hi All,
I am trying to edit the Receive.VI to be part of my RX and TX.VI. I notice that the ncGet.Vi always giving me a <0 AttrValue and no CAN mesage is displayed on the table.
Anyone Can help?
(2,565 Views)
I do not understand your question.  The image doesn't show either of the VIs you attached, and it's not clear how merging the two attached VIs is related to your question about ncGet.vi.
Have you looked at the help for ncConfigCANNet?  From the help, referring to the extended comparator: "If you intend to use CAN Objects as the sole means of receiving extended frames from the network, you should disable all extended frame reception in the Network Interface by setting this attribute to the special value CFFFFFFF hex."  CFFFFFFF hex is 3489660927, the value you're using.  That's probably why you're not receiving any frames using the "net" interface.
(2,544 Views)
Hi Nathand,
I resolved this issue yesterday by adding another ncOpen and connect the objname to ncCanReadnet.vi. and close it independently.
Thanks.
Alfred Tan
(2,540 Views)
