CAN BUS reading: Interfacing USB-8473 with LABVIEW
Hi all.
I have a USB-8473 device from National Instruments and would like to read CAN messages that are transmitted by an ECU. I am following this link for the driver setup.
I managed to install the drivers: NI-Industrial Communications for CANopen, NI-XNET (which I might not need.), and NI-CAN.
  • How would I go about writing a VI that reads the CAN messages and display them on LabVIEW?
Message 1 of 20
(5,467 Views)
Hi kulani,
Open the example finder and examine the example coming with all those CAN drivers...
(IMHO you don't need CANopen for ECU reading.)
Message 2 of 20
(5,433 Views)
Accepted by topic author Kulani93
@Kulani93 wrote:
Hi all.
Well to start with you need the CAN specification from the manufacturer to know how to decode the CAN messages.
But in general I used a Producer/Consumer architecture in my two can bus sniffer projects.
  1. The Producer loop receives the CAN messages and puts them in a Queue
  2. The Consumer loop decodes the CAN frames based on the Arbitration ID and the manufacturer specifications, then displays the data
Here's an example...
=== Engineer Ambiguously ===
Message 3 of 20
(5,422 Views)
Thank you so much, this is exactly what I was looking for. Just to see the logic and the API's that are used.
My only issue is that I can't find the NI-CAN Channel API's that you used in the example. I tried searching for them on the Function Block e.g. CAN Read, but I don't get any blocks.
I believe they should have been included when I installed the NI CAN drivers? Or please tell me how I can get them.
I have the LabVIEW Base version.
Edited:
All the software currently installed.All the software currently installed.
Self test was a Pass for the USB 8473Self test was a Pass for the USB 8473
Message 4 of 20
(5,393 Views)
I see NI CAN is for the 32 Bit version of LABVIEW and I have the 64-bit version.
Could this be the reason I can't see the blocks?
Message 5 of 20
(5,386 Views)
Hi Kulani,
Yes.
Message 6 of 20
(5,383 Views)
Thank you.
I have installed the 32-bit version of LabVIEW. I can now see the Industrial Communication Library. I currently have the CANopen blocks.
I see that the blocks differ from the example @RTSLVU posted.
Which library is that? Where can I find it?
Industrial Communication - CANopennIndustrial Communication - CANopenn
Message 7 of 20
(5,367 Views)
Hi Kulani,
As I wrote before you usually don't need CANopen to communicate with a common ECU…
The functions in RTSLVUs image are from the (old) NI-CAN driver.
Message 8 of 20
(5,363 Views)
I now have the CAN Functions similar to the example. I just had to reinstall the NI CAN Drivers to be inclusive of LABVIEW 32 Bit.
Thank you.
NINI
Message 9 of 20
(5,350 Views)
As you are using the old USB CAN dongle, you can't use the Industrial Communication Library
You need to use the old NI-CAN library og NI-XNET with NI-CAN compatibility.
Message 10 of 20
(5,349 Views)
