CAN 9853 module or port reset in programming.
HI,
I am using NI 9853 module to read CAN data from other device(one each to one connection through two wire) continuously. Meanwhile i have shorted the CAN_H and CAN_L data bus(manually). My 9853 module has  stopped reading data.Again i leave the CAN_H and CAN_L in same state(without shorted). but again  9853 module is not reading the data.So why it's happening?? Module(CAN port) is going in sleep mode??how to reset the port in programming.
(2,532 Views)
Hi Risuraj,
I use those 9853 modules in cRIO chassis and completely handle them in the FPGA: there you can use a Reset method for each CAN port…
(2,530 Views)
What is mentioned the scenario that time i want to read the status of NI 9853 module.how i will read the status of NI 9853.i am seeing two function in fpga to read the status of module attached here.when i will short the can high and low.what will happen with the module.
(2,495 Views)
you can read an error from the standard IO read node...
(2,491 Views)
