CALL EXE
Hi all :
please i want to call exe file from labview ,, please see attach file  ,,,  copy allthe files in spacific directory such as c:\temp
then run DUMP.BAT  file ,, as you can see this create csv file ,, i want to connect this DUMP.BAT through labview to create this CSV
how can i do that
thanks
(2,681 Views)
Hi elyan,
i think it should be work if you connect the path to "Open URL in Default Browser.vi"
Mike
Message Edited by MikeS81 on 02-12-2008 08:35 AM
(2,676 Views)
Instead of using your batch file, use "system exec.vi" and run directly your "EliDumper.exe".
I couldn't tried this application because this .exe return error.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,671 Views)
thanks for your quick answer
did you try it ,, can you send me vi that do this action
i don't really know how to connecte this *.bat ... ,, and sorry the jpg not clear
thanks very much
(2,665 Views)
Hi elyan,
i think this could work. Save the vi in the same path as your batch file.
Mike
(2,655 Views)
