CAD Modell STEP
Hello
does anyone know if it is possible to load and display STEP files with a CAD in LabWindows or LabView?
If not, does anyone know an alternative how this could be done with LabWindows or LabView with a third party product?
Thx in advance
OZ
(5,167 Views)
Are you wanting to display 3D models in LabVIEW or just 2D representations? And is this only for display purposes or are you trying to integrate the STEP file into a program?
This KB shows how to import and display 3D models using a *.stl file (not the same I know, but might be helpful).
dK
(5,149 Views)
Hello Daniel
If it is possible I want to display 3D models, only for display purposes, and if possible I want to manage the colour of the surfaces, that means, some surfaces in red some in green for example.
best regards
Oliver
(5,144 Views)
@OZ_68
So I would definitely take a look at the KB I linked above. I know that it's referencing STL files but it might give some hints into how to do the same for a STEP file. As for changing the color of the surfaces of the model once it's imported into LabVIEW, I can assume that that is going to be incredibly difficult (if even possible).
I would recommend seeing what you can come up with and then posting/asking specific questions or problems you run into. That will make it easier for the community to help out.
dK
(5,139 Views)
