C++ to LabView
Accepted by topic author lmontoya
...or
Jim
Message 11 of 13
(948 Views)
Jcarmody, You must actually submit you message with the attachment before you insert the image.  That way the attachment has its permament file location on the web server.  You apparently inserted it while you were in preview mode before submitting, which means it only as a temporary file location.
Here is the image.
By the way, you used Insert into Array which will cause all of the elements after number for to change indices.  You should have used Replace Array Subset.
Message Edited by Ravens Fan on 12-11-2008 01:13 PM
Message 12 of 13
(947 Views)
Thank you Jcarmody
Using the  expression node it's better and easier, It's the same result than to use a Formula node
Message 13 of 13
(940 Views)
