C code
Hi All,
I have this checksum problem. Previously i am using C programming to do the checksum but since LabVIEW does not have a c code function (please correct me if i am wrong), i would need to convert/model it from C to LabVIEW model.
Say i have these few hexa values that i need to compute a checksum (81FF, 178B and 94) and the resulting checksum should be 65E2(hexa). I have tried the VIs of some of the past checksum posts but am unable to get the desired result.
Also, let's say the values that i need to compute a checksum are not of the same format, e.g 81FF(hexa) 1234(decimal), how can i go able to implement a checksum function for these two numbers?
Please help. Thank you.
(4,330 Views)
sorry for the double post as there was some problem with my PC and when i refresh, it got posted again. How can i remove this post?
(4,322 Views)
Click options from the right top and click report to moderator.
For the rest of us continue here
(4,313 Views)
