Buttons becomes unresponsive when event runs
I have two independent while loops in a VI. One while loop have an event structure. Buttons becomes unresponsive when event runs. Is there any solution to overcome this.
(4,052 Views)
Accepted by topic author jawadtld
If you edit the event you can see the option "Lock Front panel", if you uncheck that your FP will not be locked. But the wiser method is not to perform any operation inside the event structure.
(4,047 Views)
Thanks a lot. It solved my problem.
(4,030 Views)
Well, it solved the symptoms, but most likely the bigger problem is still present.
As has been mentioned, you should not run interactive or lenghty code inside event cases.
(4,021 Views)
Thanks altenbach you are correct. But fortunately I have shorter code inside event class. It is for playing a sound. It becomes a problem only when the sound file size bigger (takes some time for loading sound file). Attaching snippet.
(3,984 Views)
