Button action only from the second click on
Hello, everybody!
I´m facing a weird problem on my application. I have a button that takes action only from the second click on. My vi has several buttons, all of them have the same type, and all of them work properly(since the first click) except one.
I gave up a few minutes ago...any ideas?
Thank you,
Luanna
(2,972 Views)
Hi
Well this sounds quite strange. The best way to help you is to comment your vi. I think a picture is not enough, as we have to see the behaviour.
So - is it possible for you to post the vi here?
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,965 Views)
Luanna,
I agree with Bektho that if you post your vi, we could suggest better.
Are you using event cases to monitor the button click action?
(2,953 Views)
I wonder if you set the mechanical action of the offending button to a different setting than the others?
(2,942 Views)
