Built an XY graph?
Hi everybody!!
y want to built a graph with this values:
X values: -85dbm, -86dbm, -87dbm, -88dbm
Y values: goes from 0.001 to 0.200
Y values are generated in the program as ABC variables
(2,754 Views)
Look at the following example that is attached in 6.1 version.
I'm building an array with the X-Values, a second array with the Y Values and compine them with a cluster into an XY Graph.
See also the examples of the XY Graphs
There are 10 kind of persons. Those who understand binaries and the others.
(2,741 Views)
XY graphs are built as a 2D array where each row holds one value for X and one for Y. Use the example finder (Help>>Find Examples) to find examples of how to do this (search for "graph"). Change the name of your x axis to dbm and that's it. You can also change the values in the scale and turn off autoscaling (using a right click on the scale) if you want the graph not to autoscale.
___________________
Try to take over the world!
(2,739 Views)
