Building vi.lib/Utilities in a Packed Library searches
If I build a VI in a packed library, which contains some items from the vi.lib/Utilities folder, the build produces the 'Searching' dialog.
For example a VI containing the 'Check if File or Folder Exists.vi' produces this symptom (see screenshot attached).
I've tried mass compiling my project and also mass compiling the vi.lib/Utilities folder and it doesn't fix it.
If I uncheck 'Remove unused polymorphic VI instances' & 'Remove unused members of project libraries' from the Additional Exclusions build page, it does fix it, but my build is 1/3rd bigger in file size than if I wait for all the dependencies to be searched for & found.
Is there a reason anyone knows why it's doing this and is there a better solution than bloating the compiled file?
(3,659 Views)
Hello Duncan,
Can you post some example code illustrating the issue?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,632 Views)
Hi Thierry, thank you for replying.
Sorry it's taken me a couple of days to reply.
I've attached a little project, which comprises an exe, which calls a VI inside a packed library. The child VI displays it's call path and checks if the path exists.
Just as an extra, I've included a little pice of code to write an ini file as that's another example of something which generates the Searching dialog.
When I build this, I get quite a few paths searched for!
I've zipped it up & attached it (The project was in the folder D:\National Instruments\VI Lib Searching)
Many thanks
Duncan
(3,613 Views)
Accepted by topic author DuncanW
Hello Duncan,
I have tested it with LabVIEW 2011 and everything seems to work.
Which version of LabVIEW are you using?
Kind Regards,
(3,608 Views)
Hi Thiery,
I've just realized this was still marked as unresolved.
I was using LabVIEW 2010, but I tried this in 2012 SP1 and it works fine.
Cheers
Duncan
(3,526 Views)
Thanks for doing the update! 🙂
Kind Regards,
(3,512 Views)
