Building multiple plots on a single XY graph
I'm trying to build multiple plots on a single XY graph and I tried to "Represent each XY data point in a cluster. Then, create an array of these clusters to represent an entire data set. This method makes it possible to display multiple data sets on a single XY graph." but no this is not accepting. With one cluster, everything is okay, but with two, its not happening.
(6,022 Views)
Accepted by topic author dilge
Looking at what you have, I think you are very close. You need to use the build array function instead.
I think this is what you're after, bundle your X and Y pairs together, then build an array of that.
Hope that helps.
(6,003 Views)
Help -> Find Examples -> Search "xy graph" -> "XY Graph Data Types.vi"
this has all variations of how to put data into xy-graph
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(5,991 Views)
