Building installer with MAX 5.4 included prompts search for NI-DAQmx 8.5 disc
Just recently, I has a similar problem. However, I needed to download the old versions, unzip them and "install" them. During the "installation" process nothing was installed because I had newer versions. However, if I pointed to a folder without doing an instalation, the installer would fail. Once a did an installation of the old stuff, it worked no problems.
Cheers,
mcduff
Message 11 of 15
(794 Views)
mcduff,
Thanks for the info, I'll give that a try.
Bandit.
Message 12 of 15
(777 Views)
mcduff,
Thanks again for the info, my installer has now built without any messages. I will test it tomorrow and report back, but this looks good. 🙂
Bandit
Message 13 of 15
(769 Views)
Bandit,
Glad to hear that everything is working out.
One thing that may cause a problem, I know because it caused me a problem, is the bitness of the installer and target computer. I spent a lot of time installing the old versions to make an installer, than I got stymied because my computer was 32 bit and the target computer was 64 bit. The intsaller did not give any error messages on the target machine, it just did not work. I did not have time to try an make a new installer.
Cheers,
mcduff
Message 14 of 15
(758 Views)
Just to report back that the installer now works fine. thanks once again for all the helpful replies.
Regards.
Bandit.
Message 15 of 15
(742 Views)
