04-13-2005 05:27 PM
04-14-2005 06:21 AM
04-25-2005 03:30 PM
04-25-2005
04:06 PM
- last edited on
11-11-2025
07:13 PM
by
Content Cleaner
Your VI is very big, so it's hard to get into for someone who doesn't know it.
Here is what I suggest:
First, if you're using the default window settings, the window should not disappear.
It sounds like you're feeding F into the FP.Open Property or maybe Hidden into the FP.State. What I suggest you do is go through all the property and invoke nodes in this VI and in the subVIs and see if you can find if one of them is doing this.
Also, you definitely do need to include all dynamic VIs. While missing a VI should not create what you're seeing, it is possible, for example, that because a VI can't be found, there is an error which causes the behaviour you're seeing (although when a VI isn't found, you should get a dialog asking you to locate it).
In general, I would say your VI is very big and seems to have a lot of redundant code (I didn't look into it, so I can't say). I suggest you read the LabVIEW style guide, which gives some tips on application design.
I hope this helped.
04-26-2005 09:01 AM
04-26-2005 09:15 AM
@IBAHKA wrote:
wouldn't the same problem happen when I run the vi as a vi, before I build the application.
04-27-2005 12:56 PM
04-27-2005 02:25 PM
04-28-2005 02:55 PM
04-28-2005 03:19 PM
