Building a Toolkit
Does LabVIEW allow programmer to build a toolkit of their own?
For example, creating a palette that has the subVIs that I created.
Thanks in Advance
Keeper
(3,473 Views)
Hi keeper,
yes it´s possible. To start you can copy all your vi´s into the userlib folder in your labview folder. If you do it, you can see your vi´s in in LabView in the user vi´s.
Hope it helps.
Mike
(3,469 Views)
Sure.
In the tools menu, select advanced, and then edit palette. Add any
directory, library or menu you like.
Wiebe.
(3,462 Views)
