Building a Selection Set (array)
LV 8.5
Hi all. I am having trouble with a sub-vi that's purpose is to take a long 1D array of raw data and allow the user to select sections to build a 2nd, shorter test set array. It must also be able to point to the array index for the selected (and selection set) values as they are actually index values in themselves.
I tried using the sub-vi nodes as input=control, output=indicator but could not come with a method. So I tried using input writes to indicator, then read property value of the indicator. I still can't read the value and the index. I'm sure this is proven technology. How is it normally done?
Labview 8.5
Meas Studio 2008
(2,987 Views)
walter,
To clarify, do you want the values added to the output array at a specific location or just prepended to the array?  Currently, your first example takes whatever element you have specified from the first array and just adds it at index zero to the second array.  Can you provide a little more explanation of exactly the behavior you are going for?
James K.
(2,948 Views)
This is back-saved from LV12, and I don't have LV8.5 around, right now, to try it.
(2,935 Views)
