Building Labview Installers/Executables
I am building an installer for an executable in Labview.  When I build the installer, I am including both the LV Run Time Engine (of course, since this is the main reason for the installer) and also the VISA run-time installer.  Once this installer is built, I then have a complete self-contained installer so that my application can be run on any computer.  This works well and I am very happy with it.
The one caveat is: Sometimes I am writing these applications to be run on a piece of test equipment, calling out the instrument as a localhost VISA resource.  This is a pseduo-embedded type of application in that the piece of test equipment, while it is a Windows XP (embedded actually) computer, is typically not as powerful as a full-blown PC host computer.  My only complaints are 1) that the installer, once it includes all the necessary components, is a 75 Mb file, which is tough to distribute sometimes (requires me to put it on a download server) and 2) when running on the "less powerful" PC i.e. the piece of test equipment, the application is quite slow in starting up (5 seconds or more).
So, I would greatly appreciate any tips to either 1) reduce the amount of raw data required to provide installers for my application, including LV Run-Time and VISA Run-Time components and/or 2) make the application startup to be quicker somehow.  I get the feeling that my applications are relatively simple and could be accomplished with a 500 kb program that runs super-fast and my solution is, instead, to provide a 75 Mb program that takes several seconds to even start.  I realize that this is the price that I pay for using such a powerful environment such as Labview to solve the problem, but was just looking for tips to minimize what seems like overkill.  I would completely understand if there wasn't much to do, but was hoping for any tips.
Greg
(2,995 Views)
My first tipp is not to use VISA, there is(are) some other drivers for serial interface. Or are you use other interfaces?
(2,974 Views)
Thanks for the reply.  I am calling the localhost address (LAN loopback address 127.0.0.1), so I am using the TCPIP I/O interface of VISA.  You bring up a good point though, maybe I could call a TCPIP specific driver instead of VISA.
(2,961 Views)
I don't really understand why you use VISA forTCP/IP communication.
There are some other VIs (without VISA) for TCP/IP communication in LV Communication Palette.
(2,942 Views)
