Building Bluetooth program on LabVIEW
HI Les,
Not too busy I hope! Smiley Happy  I managed to get around the Bluetooth adapter problem and the Bluetooth Discover worked well. But when I tried to obtain the data from the data out point of the Bluetooth Read I was unable to get anything. When I run the VI, it works with no errors but when I probe at the data out point there was nothing. I was wondering if you have the time, can you check my Bluetooth Read VI just to see if I connected them correctly.
Thx!!!
Message 11 of 13
(1,221 Views)
Try wiring a constant for the "number of bytes" to read.  It is unwired, and the default is 0.  The simple Bluetooth client example shows 2 instances of Bluetooth read, the first reading 4 bytes to get the data size, and the second reading however many bytes were gotten from the data size.
Message 12 of 13
(1,216 Views)
Hi Zen,
I'm having a similar problem as you, i.e. NEW at bluetooth labview Smiley Very Happy I'm currently working on a school project which requires a bluetooth communication between my device to my PC.
I'm trying to create the bluetooth VI too. I'm just wanting to make sure, is it safe for me to create a bluetooth application VI using the example given (http://zone.ni.com/devzone/cda/tut/p/id/3260)?
My device is connected to a bluetooth module (http://www.rfsolutions.co.uk/acatalog/Toothpick_Bluetooth_Module.html) It will take the signals from the circuit so it could transmit wirelessly to my PC. I've not tried creating any VI yet because i'm still uncertain of it.
regards, aisyah
Message 13 of 13
(1,146 Views)
