Building 32-bit application with LabVIEW 64-bit ???
we're facing heavy problems with LabVIEW 2010 (32-bit) building our application due to huge memory usage of the compile process. So we're considering to change to 64-bit LabVIEW on Windows 7 Professional (64-bit). Some of our customers still use Windows XP Professional 32-bit. As I found out it's not possible to build 32-bit applications with LabVIEW 64-bit. Is this correct or did I miss some information? In LabWindows/CVI it's already possible to compile for 32-bit or 64-bit.
Tyler
Certified LabVIEW Architect
(7,039 Views)
Correct, you can build 32 bit application with 64 bit windows PC.
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
You can use virtual machine (32 bit windows)  on 64 bit windows machine, build your applcation there.
(7,031 Views)
Sorry i missed 'not' , you cannot build 32 bit application on 64 bit windows machine.
(7,028 Views)
Hello all,
                I am also facing same problem, i want to install application built on 64 bit on 32 bit computer. As mentioned by puneet it can be done using virtual machine. Where I can find this software and infomation about this.
Ranjeet
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(6,896 Views)
