Build specification - EXE file not working
I have got the following error.
A VI broke during the build process from being saved without a block diagram. Either open the build specification to include the block diagram of that VI or enable debugging to include the block diagrams of all VIs in the build. Report this error to National Instruments technical support.
It is in Registry Handle Master
2023 version
(687 Views)
Did you try the suggested workarounds?
Is this a VI that ships with LabVIEW or your own?
Did you report to tech support? (posting in the forum is not quite the same).
(568 Views)
