Build path
Quite a basic one this...
I want to create a file - say a spreadsheet, as shown in the attached file.
I want it to be in a fixed directory - say the desktop as in my example, but to have a variable file name - a time stamp for example (although it is just shown a fixed "test.xls" string in my example).
I would expect my example to create an excel file called test.xls in the "C:\Documents and Settings\db134336\Desktop\" directory.  Why doesn't it?
Dan
(3,738 Views)
Is there an error returned by the write to spreadsheet.vi?
Ton
My LabVIEW Ideas
(3,732 Views)
No, it just brings up a "Choose file to write" dialog box, as it would if the file path pin was unconnected.
If I connect a File path indicator box to the file path 'wire', it just shows a <no path> message.
(3,728 Views)
So you probably have the answer : the path is not a valid path. Check everything ....
Chilly Charly    (aka CC)
(3,720 Views)
