Build error in LV8.6
I having trouble building my installer, the rarity of this error is that the previous weeks The build works OK, I thought my Labview  had been damaged, I have uninstalled it and I reinstalled again everything but still I have the same problem
I am working with Labvew 8.6  in windows XP, I have searched the forum but cannot find the exact same error description.
Hope someone can help me out of this error
(3,370 Views)
Does it happen every time you build an installer? Or just when you add something?
Could you please describe better your problem?
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(3,307 Views)
Yes, it happen every time that I tray to build an installer !!!
Regards
WSR
(3,299 Views)
Could you please explain better what is going on? Please show me a screen with the options you are choosing on the installer. Thanks. Best Regards
Luciano Borges
(3,280 Views)
Hi Lucianogob,
Thank you by your help, the rarity of this issue is that before I could to create the installer without any problem following the same procedure
(3,275 Views)
And about the additional installers option?
Luciano Borges
(3,258 Views)
