Build application question
Hi all.
I have to distribute some applications and then I use the build application
tool, but, my employer want different messages that the defaults messages,
so if anyone know if its possible, please help me.
Eric
(2,884 Views)
What default messages? If you are talking about when right clicking on a control, I don't believe you can change those.
(2,884 Views)
Which default messages?
For the messages during installation, look into the file
Applibs\distkit\langage.ini where are stored the strings used by the
installer. Take a backup copy and modify for your own purposes.
I have never tried that but it should work as expected. Usual disclaimer.
If you want to translate application default menus, use custom menus or
install the Run-Time Engine for your language on the target machine.
Jean-Pierre Drolet
Scientech R&D
LabVIEW, C'est LabVIEW
(2,884 Views)
