Build application and installer to work without LabView installed.
Hi!
Can someone please tell me how to build an installer
in LabView, that can be installed on a different computer
and run my program without having to install LabView
on that computer?
Børild
(2,895 Views)
You just go through the nomral process of creating the installer:
http://zone.ni.com/reference/en-XX/help/371361B-01/lvhowto/build_installer/
Just make sure you select the run-time engine (default I think) and VISA if needed...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,882 Views)
As TMGomez explained..
Can you tell us which version of Labview you are using?  Is it LV7.1 and older or LV8.x?
The reason for asking is that the steps have changed since LV8.0.
RayR
(2,868 Views)
