Build an executable from Labview VIs
I am doing a program for automating data with LabVIEW.  I create my GUI. This application will be used afterwise in another PC where there isn't LabVIEW installed. What I want is to run only the GUI, without opening Labview front panel every time i want to run the program on. So what shall I do to have only an executable and not run my VI from the developement environment?
I Thank You in advannce.
(3,235 Views)
Here are some info : https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
CLAMaxime -- Kudos are a great way to say thank you
(3,229 Views)
Note that if you don't have the professionnal version of LabVIEW you will have to buy the Application Builder as a separate entity in order to create executables. If you have the professionnal version or the application builder your vi need to be part of a project to create an executable.
Ben64
(3,210 Views)
Hi!
It's clear for me now, Thank you so much for your responses
(3,183 Views)
