Build a cmd-like interface in labview
hello i have a string indicator in labview formatted as follows:
"Select which test to execute:
1- Test01
2-Test02
3-Test03"
and from a string control i pick which test to run by typing in the index (1,2,3). Once i do that i need the string indicator to be replaced with a series of subtests. Like for example, lets say i pick test 01. the indicator would now say something like:
"Test 01 subtests
1-Subtest 1.1
2-Subtest 1.2
3-Subtest 1.3"
by choosing an index here, another menu appears on the indicator
how can i do that? i tought of using a series of case structures but, given the amount of sub-menus i have, the code would become bloated with case structures. is therer an easy way to build an interface like this?
thank you
(651 Views)
Have you considered a tree control?
Jim
(646 Views)
