Build Error
I'm trying to build my application, but I'm encountering this error. Any suggestions? My library, AB_Source_Library, is not locked.
Thank you,
Error 1562 occurred at: Property Node (arg 1) in AB_Source_Library.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reasons:
LabVIEW: The specified library or project is locked.
(1,487 Views)
Have you tried checkbox roulette already?
https://youtu.be/HKcEYkksW_o?t=2030
(1,433 Views)
I tried the mass compile, and in the results, I have some bad VIs. Do you have any idea how to fix this? There are no broken arrows in my VIs
Thank you,
(1,404 Views)
Do the mass compile results have literally any details other than "bad VI"?
If you look at the VIs that say they mass compiled broken, is there anything in common among them?
It will often be things like conditional disable structures or DLL calls that can cause this, but nearly impossible without clues.
(1,371 Views)
Thank you for your response.
The only information I have is that I have some bad VIs. I can share the logs with you.
in my Brake Function runtime.lvclass I'm using the LabVIEW PID Control Toolkit with the LabVIEW Control Design and simuation module
#### Starting Mass Compile: ven. 20 déc. 2024 08:22:37
Directory: "C:\DUF1 SPC\SVN"
Skipping project already in memory: C:\DUF1 SPC\SVN\Source\DUF PRJ SPC.lvproj
### Bad VI: "DUF TST Main Supervision Communication.vi" Path="C:\DUF1 SPC\SVN\Source\Host\Test VIs\DUF TST Main Supervision Communication.vi"
### Bad subVI: "SIM PID Integral Gain.vi" Path="C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\Simulation\Model Libraries\PID\subVIs\SIM PID Integral Gain.vi"
### Bad VI: "Scaling editor node.lvclass:Scaling Configuration.vi" Path="C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\NI\DCAF Templates\DCAF Scaling\editor node\to override\Scaling Configuration.vi"
### Bad VI: "Brake Function runtime.lvclass:Regulation Subsystem.vi" Path="C:\DUF1 SPC\SVN\Source\Modules\Brake Function\module\execution\SubVIs\Regulation Subsystem.vi"
(1,357 Views)
