Build Error AB_Build
In LV 2023 Q3 (64bit), when I try to complite an exe, I received the following error message:
"Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error 1035 occurred at Invoke Node in AB_Compile_Before_Reading_VI_Exec.State.vi->AB_Source_VI.lvclass:Open_PrepReference.vi->AB_Build.lvclass:Update_VIObjCache.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: (Hex 0x40B) Operation is invalid for this type of VI.
Method Name: Compile:VI"
Did you please have any ideas to help me?
(2,318 Views)
Try the tips in Darren's presentation starting around the 34 min mark:
https://youtu.be/HKcEYkksW_o?t=2033
(2,247 Views)
Accepted by topic author Totov
Hello Gregory,
Thank's for the tips.
I managed to re-compile by re-importing all files into a new LabView project.
(I assume the project was created in an older version of LabView)
Best regards
(2,221 Views)
