Build Array - 4 elements which have 3 empty array and 1 array with value and build into cluster of 3 element to display in graph chart, the graph chart still display the empty array with the value 0
the empty array still appear in the graph chart, with the value 0, how to make it not to appear in the graph chart?
i have variables to determine which array is empty or have value in it
(2,778 Views)
When you use the build array with one array that's empty and one array that's not, you cannot get a 2D array with one row or column that's empty - it's simply not a valid array. So that's where your 0 values come from. You could fill the empty arrays with NaN or set the plot color for those arrays to be transparent.
(2,778 Views)
Hi Dennis,
Didn't know that the build array have such behaviour, if i initialize array and the demension size is 120000
and i build 3 such arrays in the same time, will it slow down the program?
(2,778 Views)
Initializing arrays and using Replace Array Element is usually faster than building arrays in a loop because of memory allocation issues as the array grows.
You may not want to display on a graph more than a few hundred points at a time. The user cannot interpret more than that and updating the screen can be very time consuming with large numbers of points. Display speed is a complex function of OS, graphic hardware and software, much of it outside the control of LV. Also, updating a graph more than a few times per second is a waste of resources.
Lynn
(2,778 Views)
