Build Application Error
I am consistently getting an Error 26071 when I try to build my application to make an .EXE.  I am usling LV6.1, and Application Builder for it.  The app. works just fine from within LV itself.  There are no errors.
Specifically, the error message is "Error 26071 occurred at Build Application.vi >> Dist Call Create Installer.vi >> Win Install Create.vi >> Win Install Add Files.vi >> MSI DK Add Shortcut.vi", with possible reasons stated as "Windows GetCommError:  The hex value if the code us x65D7".
This code used to build just fine before I added some code using the Winevent.llb library, retrieved from NI.  I had done a mass recompile on it and my code, just in case there was LV version compatibility issues.  I also copied the specific vi's from Winevent into my library and did another mass compile, to no avail.  I am using VISA serial port vi's (the GetCommError made me think this might be related).
Any ideas on what I'm doing wrong or what I'm missing?
Jeff
Message 1 of 9
(4,850 Views)
Please help... I can't finish this until I get past this.  TIA.
Message 2 of 9
(4,828 Views)
Check out this knowledge base here [link removed; article no longer available] and let me know if that helps solve your issue.
Tyler H.
Message 3 of 9
(4,819 Views)
Yup, that got it.  Thanks.  And I did search the knowledge base.  Just not too well.
Message 4 of 9
(4,815 Views)
Could you please tell me how did you solve it because I'm having the same problem and the link of the page in the replies is missing.
It will be highly appreciated if you could help me.
Message 5 of 9
(4,049 Views)
Hi Haitham,
you are replying in a 13 year old thread.
Are you really still using LabVIEW 6.1?
Message 6 of 9
(4,045 Views)
Try and register MATLAB as a COM server. You should be able to do so by following either of the links:
Message 7 of 9
(4,040 Views)
Hi GerdW
thank you for your prompt response.
Yes, I'm still using it since our application is rather old.
I made some modifications on some VIs within it, mass compile it with no errors
but still have this problem at the end stage of building the application.
I know this is very old , but I thought that you could remember anything that could help. 🙂
Message 8 of 9
(4,029 Views)
Hi Everyone
It seems that the problem was resolved after I made Mass compile a couple of times.
I'm not sure why did that happened but things went fine and the application is running.
Thank you all.
Best regards;Heart
Message 9 of 9
(4,011 Views)
