Build Aplication
I wont to build Aplication.
I tryed to do this, and it's work, but after I done this, I have seen:
Build finished!
Remember that the LABVIEW Run-Time Engine version 6.1 must be installed on
any machine that is going to run this application.
And that is not this what I expected.
Is that pasible to build "independent" application?
thanks Duzy
(3,115 Views)
Hi Piotr,
You Can't build an "independent application". You must to install the Run-time engine at any computer that you want your EXE to run.
Like Visual Basic or VB .Net, that you must to install the VBRUn, before exeude.
Hope it Helps...
(3,115 Views)
