Bug question...
I have a subVI which runs perfectly and returns the correct data when run by itself.  But when I call this subVI from another VI the subVI returns wrong data. In addition what confuses me is that when I use Highlight Execution to debug the VI which call that problematic subVI the subVI returns correct data(?!!).  I use the same parameters for the subVI when I run it independently and when I run is as  a subVI from another VI. Could someone tell in which direction I should look for this bug? I don't even understand what is causing this inconsistency. Thanks.
(2,831 Views)
Without seeing the code two things come to mind.
1. If it works on "highlight execution" mode then it points to a timing issue.  Do you have multiple calls to this data?  Perhaps a race condition.
2. If the data is correct when run alone and incorrect when called as a sub-VI is there a data type mismatch?  Are there any coercion dots or are you doing any typecasting or variant to data conversions that may not be properly formatted?
Hope this helps.
-Dave
(2,822 Views)
