Bug in renaming Library/other components - LabVIEW NXG 5
See the attached screenshot:
Note the name of the wire to Test Suite Results and the Project structure on the left.  Originally, Unit Test Framework.gcomp was called LabViewNXG Test Framework.gcomp but I renamed it.  The project still works but the naming of multiple elements within the project carries over the old name.
Is this likely to cause a problem longer term?  Is there any way of resolving it?
Message 1 of 1
(2,029 Views)
