Bug in "Format Date/Time String Function"??
I wants to include a string to display the used time. So in every loop I
have to calculate the difference between the starttime and now. That's
ok. But when I use the "Format Date/Time String Function" to convert
into a string like "hour:min:sec" the hour will everytime start with 2
instead 0??? It's my mistake or is there really a bug inside?
Bye
Henrik
(3,266 Views)
The problem is that LabVIEW takes seconds since 1-1-1904
starting at 2 o'clock, and if you get 5 seconds, and format
this number into time/date string it is considered five
seconds since that predefined time. If you want to see the
real difference, you must wire it to an indicator and
change the format and precission to relative time.
Hope this helps.
* Sent from AltaVista http://www.altavista.com Where you can also find related Web Pages, Images, Audios, Videos, News, and Shopping. Smart is Beautiful
(3,266 Views)
> Hope this helps.
this was also my first idea...but it is so?? I took a look at the help and there stands nothing about 2p.m.!
"The date/time string is determined from the seconds (now), which is the number of seconds since 12:00 a
.m., January 1, 1904, Universal Time, and time format
string is the format of the output string."
Bye
Henrik
(3,266 Views)
it's ok..I just created my own Vi...;)
Bye
(3,266 Views)
> Hi,
the number of seconds since 12:00 a.m., January 1, 1904, Universal
> Bye
> Henrik
It also depends on your time zone setting on your PC. That quote is
based on Greenwich Mean Time.
ej
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,266 Views)
