Bug in IMAQ IntegerToColorValue ?
There seems to be a bug in IMAQ IntegerToColorValue. When converting a system color into RGB values the answer is zero for Red and Green, and a small integer for Blue. Attached VI demonstrates problem. Other colors are OK. Labview 6.1, Vision Development Module 7.0.
Martin
Message 1 of 8
(3,879 Views)
There is no such problem on my PC. The RGB color values and display are OK.
CC
Chilly Charly    (aka CC)
Message 2 of 8
(3,869 Views)
There is no such problem on my PC. The RGB values and display are OK.
But I use LV 7.1... Could that be a compatibility problem between Imaq vision 7 and LV6 ?
Message 3 of 8
(3,867 Views)
Hello Martin
I can regenerate your problem and you are right it seems as a bug!!! I will report the issue to R&D and see what they have to say. It's only like that when you choose the system color, but choosing some color from the color chart does not give this behavior.
Mohadjer
Message 4 of 8
(3,856 Views)
Hello Martin
Here is some feedback on the issue...
We should document that the VI ignores the alpha channel of the integer value, and that LabVIEW system colors use the alpha channel.
Hope this helps you out!
Regards
Mohadjer
Message 5 of 8
(3,838 Views)
Probably a user who uses IntegerToColorValue is not interested in the technical details of the alpha channel, but only in getting the RGB color components. Suggest to fix IntegerToColorValue to that effect.
Martin
Message 6 of 8
(3,834 Views)
The system colors set values in the alpha channel, which we don't use. We do correctly interpret the RGB portion in the mentioned VI's!
Mohadjer
Message 7 of 8
(3,834 Views)
I am not discussing what you are doing, I am discussing what you should do. With risk of repeating myself: When using the IntegerToColorValue, one is interested in the Red, Green and Blue content of the color, not which values that happen to be stored in the Red, Green, Blue, Alpha "slots" of the color! Thus if these values do not reflect the actual color content, the result is unasable.
Martin
Message 8 of 8
(3,828 Views)
