[Bug] Xilinx IPCore file permission problem
I just copied a CIC IPCore node from a colleagues VI and tried to reconfigure from a 2-channel to a 4-channel filter.
At the end of the process I got a file permission error for a path which does not exist on my computer (presumably it has remembered the location to save the file from my colleagues computer).
Not too big a problem except the dialog will not close and I now need to exit LabVIEW and restart to get any more work done.  In other words, a file permission error (or inexistent path) hangs the IPCore properties dialog at the last stage (at least for the CIC filter).  Not nice behaviour.
Shane.
(3,088 Views)
I realise theres a path input at the beginning of the process but even if this is incorrect, the dialog should not hang.
(3,067 Views)
Hi Shane,
please post a screenshot of the message and evaluate if the path
is really the location where your colleage created the original VI.
Which LV Version are you using exactly?
Is the behaviour reproducible?
Peter
(3,025 Views)
