[Bug Report] LV2015 Create Override Method Bug
I have found an issue in LV2015 when creating an override method of a class that has a common parent with a class in a second open project.  For some reason, I get error 1025 when creating the override.
I am attaching a zip with example projects and a document describing how to reproduce the issue.
Please verify the defect and let me know the CAR this gets assigned to so I can track when it get fixed.
thanks,
-John
-John
Certified LabVIEW Architect
(3,553 Views)
Hello jlokanis,
I have used your detailed instructions to replicate your error. I will investigate further and determine if a CAR will be filed. Thank you for your diligence!
(3,503 Views)
It seems I have the same erreur in my project (LV 2013). Since opening a second  project with same classes, I cannot create class override functions ( Error 1025).
No issue after reboot of the computer.
Can create function with same name and after them I have to make conform Vi as parent.
Perhaps this can help.
Best regards.
(3,300 Views)
