Bug: Labview doesnt start after Update to LV 7.1.1
someone here with solution for this problem?
You can reproduce it by doing these steps:
1.) Install Labview 7.1
2.) Install an executable Labview-program compiled/created with LV 7.1.1
3.) Install the LV-Update 7.1.1
4.) Try to start Labview.exe
Here I get an pop-up with the text:
Executable version (LV7.1.1) doesn´t match resource file (LV7.1)
[OK]
The only thing i can do is to uninstall Labview 7.1.1 and the Runtime 7.1.1 and the reinstall Labview 7.1.
But there is no way to install the update on a normal way.
I think the problem is, that the executable programm already installs the Runtime 7.1.1 and makes some registry-things. So when installing the update after that, then the registry is already 1/2 updated and something goes wrong.
Perhaps i only need one more registry-entry to get rid of the pop-up.#
Thanks for your help
(2,925 Views)
Edit:
Executable version (7.1.1) doesn´t match resource file (7.1).
Check your configuration.
[OK]
This is the full message-popup.
The problem has to be somewhere else. On another computer i tried the steps i described above but there i had no problems to update.
So the main-question is: What can i do against this popup?
(2,917 Views)
The problem is already reported in NI's knowledge base.
Jochen Klier
National Instruments Germany
(2,890 Views)
Thanks for your answer.
Meanwhile i found the solution. It was an other problem than the solution to your link. The Problem in your link was with the "Run-Time Engine". My problem was with the "Full Development System".
But this problem is also already solved in the NI-Knowledge-base.
http://digital.ni.com/public.nsf/websearch/6bb601ae18d54c2186256f6c007fd775?opendocument
Best regards
(2,886 Views)
