[Bug] Hiding "Event Data Node for This Case" isn't truly hidden
Unchecking the Visible Items -> Event Data Node for This Case option on an event structure will hide the event data node, but it is still possible to connect wires to it. It also gets in the way when trying to run wires near the left edge of the event structure. See the gif below, captured in LabVIEW 2020.
Is this a known issue? I've not had a chance to test newer versions of LabVIEW for the issue, but didn't see anything in the release notes about it.
(1,146 Views)
Well, they are hidden.  What more do you want?  😄  (Yes, this seems like at least "unwanted" or "unexpected" behavior, if not a BUG.)
As a workaround, I guess you could resize it to 1 node and drag it to the bottom.  Which is useless, because you could do that with them visible.
Bill
CLD
(Mid-Level minion.)
(1,139 Views)
What a fantastic idea!  My cow-orkers would never figure it out before their brains [sic] melted 😆.
(1,129 Views)
